11-17-2021 02:03 - last edited on 11-17-2021 06:14 by MarreFitbit
hi so i have recently setup my Fitbit versa and it won't go off the white log after the setup
11-17-2021 06:15 - edited 11-01-2023 18:14
Hi there, @timmy88549. Welcome to the Community Forums.
To better assist you, would you mind confirming if your Versa is stuck on the Fitbit logo? If so, please try the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
