06-08-2019
21:24
05:37
06-08-2019
21:24
05:37
Please help!!!! I've had my versa since Feb 19.
Unfortunately I'm having issues with my versa. It was once working while on the treadmill then froze up only showing the turquoise blue Fitbit logo. I've trying pressing all buttons to no avoid, even placed it on the charger- still nothing.
When I went to the settings app to try to reset my device, it gives an error that the versa isn't connected and to make sure it was attached.
This is horrible! Please help!!
Hi @luvleekey17 Have you tried the manual reset process? Restart your tracker
Did you try a Factory Reset in the settings app? If not, try that one too (scroll down to About)
Please come back if nothing works for you
Helen | Western Australia
Best AnswerHi I've tried to reset, restart, system is still frozen and wont turn off.
Best AnswerThanks for confirming that. I'll flag a moderator to halp you.
Best AnswerOK that is great.
Welcome to the Community Forums @luvleekey17! Thanks so much for taking the time to try troubleshooting the issue with your Versa's display.
We're happy to hear that our Support Team has been helping you since. Please keep an eye on your inbox for updates on your case.
Thanks for your help @NellyG!
Let us know if there's anything else we may do to assist you in the meantime.
