04-12-2020
19:07
07:52
JuanJoFitbit
04-12-2020
19:07
07:52
JuanJoFitbit
My Versa has been stuck on the logo screen since last Friday. I've restarted it dozens of times and let the battery drain and recharged it a few times as well. No change.
Moderator edit: format
Hi @Joeggs, due to the recent events, I apologize for the delayed response. However, let me welcome you to our Fitbit Community.
I would like to follow up and help you with your Fitbit Versa since the screen is stuck showing the Fitbit logo. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try one more workaround that has been helpful for this type of issues. Try a factory reset by following the steps below:
Keep me posted on the outcome.
Best AnswerHi @JuanJoFitbit, thanks for your reply and no worries for the delay, I appreciate the help.
I've tried the workaround but it didn't work. The watch vibrated and shut-down for a few minutes but stayed at the fitbit logo screen when it restarted. The workaround hasn't worked since.
Best AnswerMine is doing exactly the same and I’ve only had this one for a month and half pretty annoyed with it my other versa won’t hold its charge that is only a year old
