05-28-2019 11:32
05-28-2019 11:32
My Versa has just started constantly vibrating and switching screens on its own, mainly to the start exercise or the notification center as if i'm checking for notifications. I have tried to restart it and I cant get it to turn off. Anyone had this? It's like 20 times a minute flicking back and forth to homepage and notifications.
05-29-2019 11:36
05-29-2019 11:36
@Andrea.b welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the display switches screens and vibrates all of a sudden. By the way, thank you for restarting your Versa before contacting our forums.
I would like you to try changing the clock face. Make sure that the clock face is one developed by Fitbit.
If this doesn't fix the issue, please try a factory reset. To do this on your device, open the Settings app > About > Factory Reset or Clear User Data. Sync your device before the factory reset in order to avoid losing your current data.
Keep me posted on the outcome! ![]()
Best Answer12-14-2022 14:50
12-14-2022 14:50
I am having the same problem I changed the clock face it was still doing it I factory reset it. I can’t figure out what else to do
