05-26-2019
23:32
11:59
JuanJoFitbit
05-26-2019
23:32
11:59
JuanJoFitbit
Versa hasn't synced since 5:30am today, after a while says tracker not found, not had this problem before.
05-27-2019 01:03
05-27-2019 01:03
The usual things to try when you get syncing issues are:
05-27-2019 11:58
05-27-2019 11:58
@Eagle002 welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it's not syncing with your phone.
I'd just like to know if the issue persists or if it got resolved after following the great troubleshooting steps that shared my friend @SteveH.
If you found his post helpful, please accept it as a solution so other users that experience the same issue can find it easier.
Looking forward to your response! ![]()
Best Answer05-27-2019 13:33
05-27-2019 13:33
Best Answer05-27-2019 14:20
05-27-2019 14:20
Best Answer05-27-2019 15:15
05-27-2019 15:15
I am having the same trouble
Best Answer05-28-2019 00:28
05-28-2019 00:28
As mentioned in my earlier post, if none of the troubleshooting steps work for you then the best option is to contact customer support.
Best Answer05-28-2019 08:50
05-28-2019 08:50
Hello @Eagle002 and @Knitster58 I hope you're doing well, it's great to see you around. It's nice to see you too @SteveH, thanks for all your help.
@Eagle002 and @Knitster58 as you have already tried the troubleshooting steps provided by @SteveH and if you haven't contacted our Support Team yet, I would like to suggest you to try to set up your Versa as a new device, this will reset the connection between the watch and your phone. Note that none of the information previously synced will be deleted as it gets saved in our servers.
To set up your Versa as a new device:
Give these steps a try and let us know the outcome.
Best Answer05-29-2019 04:51
05-29-2019 04:51
hey guys bought my Versa in Feb and I have a LG v30+ all was working until two days ago.. so i chatted yesterday about the same thing they told me in chat basically to get a new phone because mine is not on their "LIST" so this morning a friend from work had an old IPHONE 6 and guess what still nothing so do i need to buy a IPHONE x or some thing else it just seems strange all of a sudden its not working. maybe the unit went bad. do they actually fix or swap these???
Best Answer05-29-2019 05:04
05-29-2019 05:04
I have an iPhone XR and it still doesn’t sync correctly. My sister has the same Versa and an iPhone6 and hers works just fine. Mine never synced correctly and they blame it on time zone difference.
Best Answer05-29-2019 05:10
05-29-2019 05:10
its just odd that it was working and then all of a sudden nothing . maybe ill hit up customer service again
Best Answer05-30-2019 09:22
05-30-2019 09:22
Hello @TiNy2nz and @Knitster58 I hope you're doingw ell, it's nice to see you around.
@TiNy2nz Please note that many Android phones, like yours have all the hardware requirements to be a supported device but are currently not on our list of supported devices. This means that we have not tested it for compatibility and added it to the list yet. For the time being, we don't have an specific date or time-frame of when is going they will be listed as compatible.
While these devices has all the specifications to be compatible and are currently working with the Fitbit app, it's possible to come across some issues along the way.
However, at this moment, I would like to ask you both the exact list of troubleshooting steps you've tried so far, this will be very helpful for us to check this further and determine what we should do next.
Thanks for your patience and understanding, we'll be waiting to hear from you.
