11-03-2019 15:49
11-03-2019 15:49
I just returned from Europe and my versa will not change back to North America time. Synced several times..
Help
11-04-2019 07:15
11-04-2019 07:15
If you are using the Settings page at Fitbit.com. after you make your change, you need to click Submit at the bottom of the page and then sync your tracker.
Best Answer11-03-2019 16:07
11-03-2019 16:07
Change it manually in Settings.
Best Answer11-03-2019 16:30
11-03-2019 16:30
Best Answer11-04-2019 07:15
11-04-2019 07:15
Best Answer11-04-2019 07:29
11-04-2019 07:29
Best Answer03-19-2020 09:38
03-19-2020 09:38
if you go to the app under your account scroll down all the way to advanced settings. From there select the automatic timezone and automatic location (make sure your toggles are to the right) then re-sync.
