Hi, @helga_h64! Are you talking about on the Versa itself? I'd suggest trying a reset of the Versa and seeing if that helps. Hold the button or the left button and bottom right button for about ten seconds until the device vibrates and the Fitbit icon shows up.
MakMak | Community Council
Best AnswerHi @MakMak , yes i have done reset few times still not luck .funny bc i get notification of how many steps is left for an hour but nothing showing under how many steps i have taken
Best AnswerHmm that's really strange behavior. I haven't heard of anyone else posting this, but that doesn't mean it hasn't happened. What I would suggest doing is taking a photo of it next time you get it, then getting in touch with Fitbit Support directly. You can share with them what is happening and what you have done already and have the picture as backup, since they often ask for those details, it will save you some runaround. Good luck and let me know how it goes!
