09-03-2019 11:26
09-03-2019 11:26
Hi I've been trying to find a complete list side-by-side differences of the above three products. But I keep finding websites with a lot of information that I'm not looking for. Looking to find out the exact differences and features of each individual piece.
** I am also looking to find specifically if the three products contain the same mechanisms in each watch. I don't know the technical names of the pieces, but the things that count stairs and steps and things like that. Exactly what are the main differences between the three watches. Any help is appreciated thank you
09-03-2019 11:33
09-03-2019 11:33
Hi @Kuffs there is a way to compare on the Fitbit Store site - click to go there - select compare and pick three.
Best Answer09-03-2019 11:35
09-03-2019 11:35
You'll need to click on the Versa to get that info, it doesn't show up in the comparison chart. If you click on any of the products, you'll get a run down of the features.
Best Answer09-05-2019 09:36
09-05-2019 09:36
Hi Kuffs,
I don’t know if this comparison between Versa and Versa 2 would help you. It doesn’t include Versa Lite, however. Following is a comparison I read on Wareable:
| Fitbit Versa 2 | Fitbit Versa | |
| Display | AMOLED | 1.34-inch, 300x300 LCD |
| Size | TBC | 11.2mm thick |
| Heart Rate Sensor | PPG Optical sensor | PPG Optical sensor |
| GPS | No GPS | No GPS |
| Waterproof | Yes, up to 50 metres | Yes, up to 50 metres |
| Payments | On all models | Special Edition only |
| Built-in microphone | Yes | No |
| Battery Life | Five days | Four days |
| Price at release | From $199.95 | $199 |
