02-27-2021
03:07
13:44
RicardoFitbit
02-27-2021
03:07
13:44
RicardoFitbit
Hi guys.
I went to bed last night with a full battery woke up this morning to zero % and now it won't charge it just keeps saying zero
Only had it a month so any help would be grateful
02-27-2021 10:57
02-27-2021 10:57
To see what's happening with the charge
Connect the charge cable to the watch and plug it into a PC USB port
The PC should announce a connected device with a sound, it means its connected and charging [if there is no sound, either the volume on the PC is low, or off, or the watch is not properly connected to the charger or has a fault]
if PC then announces a disconnected device with another sound, it means the watch battery is either flat or the watch is dead
anyway wait 10 minutes [for battery to get to 5%] if the watch or battery is not dead it will announce device connected again [the watch may also wake up]
if after an hour there is nothing on the watch face try starting it by pressing a button for a few seconds and waiting for the logo to appear or restarting with the buttons
if nothing comes on the screen, either there is a screen or button fault or the watch is dead - but wait
Check the button start procedure,and that the button clicks |
It probably is faulty and needs replacing where you bought it or contact Fitbit Support directly. They may be able to help you.
13:47
13:02
03-01-2021
13:47
13:02
Welcome to the Community Forums @Vickylewis2009.
Thanks for bringing this to our attention and for the details that were shared on your post. Our Customer Support team informed me that they already provided you assistance to solve your Versa issue just as @Guy_ suggested you. That being said, my best advice for you at this moment will be to contact them back if further assistance is needed or if you have any additional questions about the outcome of your case. Unfortunately I don’t have access to such information to accordingly assist you.
I'll be here if you need anything else.
