04-04-2019 13:08
04-04-2019 13:08
Please help. I can’t get my versa to pair with my iPhone X. It was working fine until Tuesday. I’ve tried everything from restarting the versa. Factory reset to turning Bluetooth off and on. I even uninstalled and reinstalled the app. I thought it was my phone. However I was able to pair my Alta with no problems.
04-04-2019 14:34 - edited 04-04-2019 14:34
Hi, if you think my post really helped you and solved your problem, see my signature. Thanks!
Best Answer04-04-2019 14:20
04-04-2019 14:20
Hi, maybe the guide I wrote to upgrade to the newest version of the Firmware might be helpfull for you, as you will get the newest version. It's using WiFi instead of BT. See: https://community.fitbit.com/t5/Versa-Versa-Lite/Hassle-free-guide-to-update-your-Versa-s-firmware/t.... Good luck!!
Best Answer04-04-2019 14:27
04-04-2019 14:27
Thank you so much I will try it! I appreciate you!
Best Answer04-04-2019 14:47 - edited 04-04-2019 14:50
Hi, you probably marked accidentally your own post as a marked solution, but this is not the solution. You can undo this by pressing the three dots in your first post and scroll down to "this is not the solution" and mark the right answer as an accepted solution, e.g. the last one I posted or the one I posted to use my guide.
Best Answer04-04-2019 14:49
04-04-2019 14:49
oops! will do.
Best Answer04-04-2019 14:50
04-04-2019 14:50
No problem, can happen to everyone ![]()
