05-25-2019
12:32
08:23
LanuzaFitbit
05-25-2019
12:32
08:23
LanuzaFitbit
Yesterday my Versa started randomly buzzing me to tell me all notifications are up to date and opening the exercise app which I actually never use. It’s draining my battery and is really annoying. It’s getting harder to go back to the home screen when the exercise app opens and I have to push the back button and bottom button like I’m going to reset to get it back to the home screen. I’ve reset and done a complete shutdown several times. I’ve only had the Versa six months.
05-25-2019 17:53
05-25-2019 17:53
@amywalker424 By reset do you mean reboot or wiping your tracker of data? Please try the latter one - performing a factory reset. This will wipe your Versa, so please sync first. You will also need to delete your tracker from your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a replacement device in the Fitbit mobile app. Good luck!
05-25-2019 17:53 - edited 05-25-2019 17:54
Hi @amywalker424 Have you tried doing a Factory reset? If not, give it a try (settings app on the watch and scroll down to About). If that doesnt help, please come back here.
Woops @Marrrmaduke got in before me!
Helen | Western Australia
05-25-2019 18:14
05-25-2019 18:14
@NellyG No worries. The more the merrier! 😄
05-26-2019 02:34
05-26-2019 02:34
05-26-2019 08:23
05-26-2019 08:23
Welcome to the Forums @amywalker424. Hi @Marrrmaduke and @NellyG.
@Marrrmaduke and @NellyG, thanks for being around to help! @amywalker424 Thank you for going through all of the steps that were recommended.
@amywalker424, Our support team will be getting in touch with you about this situation via email. Be sure to keep an eye on your email's inbox, spam, and trash folders for their mail. They will be more than happy to help you figure out what is going on and find a solution.
Let me know if there is anything else that we can help you with.
