08-11-2021
08:34
09:22
JuanJoFitbit
08-11-2021
08:34
09:22
JuanJoFitbit
I traveled to the East Coast and my Versa adjusted to local time (just like my phone). However, When I returned I cannot get it to synch to Pacific time. Help!
Moderator edit: format
08-11-2021 09:21
08-11-2021 09:21
@MJP118 Welcome to our Fitbit Community. Regarding the time change issue that your Fitbit Versa has experienced, I'd like you to restart it as described in this help article. After this, sync your Fitbit device and see if the time zone gets corrected.
Hope this helps.
Best Answer08-11-2021 21:27
08-11-2021 21:27
08-12-2021 04:29
08-12-2021 04:29
@MJP118 Thank you for getting back. Since the issue persists, please try setting up your watch from scratch, as a new device and see if the issue gets fixed.
See you alter.
Best Answer08-12-2021 05:04
08-12-2021 05:04
Best Answer08-12-2021 06:49
08-12-2021 06:49
I am having this same issue and it seems to only have been since the latest update to the tracker. I don’t want to have to set it up as a new device bc I’ll lose all data. I would highly recommend that you look into finding a fix for this bug bc I believe it’s in the software.
08-12-2021 10:02 - last edited on 08-12-2021 19:47 by LiliyaFitbit
Please provide instructions on how to start from scratch
Thanks
Best Answer08-31-2021 11:09
08-31-2021 11:09
