08-25-2021
07:54
13:54
BraulioFitbit
08-25-2021
07:54
13:54
BraulioFitbit
Hi
My versa 2 is still not receiving notifications after nearly 2 months now. Customer support has been less than helpful.
Is there any news? Is it possible to get a new watch if it isn't going to get fixed?
Thanks
08-25-2021 07:57
08-25-2021 07:57
Hi @Jl329 you were given suggestions from a Fitbit moderator here - click to read. Did you try following those again? There was recently an update of the Android app, so see if you have that, too.
08-25-2021 11:05
08-25-2021 11:05
I've done both and still not working.
I have a notification error message saying I need to restart my phone but when I do, nothing changes!
08-25-2021 11:39
08-25-2021 11:39
@Jl329 you have to tell the Fitbit app and your phone to allow notifications. Be sure you've allowed both to do it.
08-25-2021 11:41
08-25-2021 11:41
I haven't changed any settings and it was working perfectly fine before 😞
08-25-2021 11:51
08-25-2021 11:51
True, but sometimes it doesn't hurt to double check. Be sure to log in and out of your app and reboot the phone.
08-25-2021 13:42
08-25-2021 13:42
You aren't alone. There seems to be nothing we can do. Followed every FAQ, every suggestion, everything is turned on and up-to-date. Honestly, I feel like my Versa 2 is almost pointless now.
I might as well be wearing my son's Ace3.
Does your Versa show up in your Bluetooth? Does it stay connected to WiFi? Mine won't do either.
08-26-2021 13:41
08-26-2021 13:41
Hi @Jl329, @Keekers09. Thanks for stopping by.
Thanks for the input and assistance provided @Odyssey13 😀
Since you contacted customer support already, I recommend you to contact them to get an update on the difficulty that you're still experiencing with notifications on your Versa 2 @Jl329.
Thanks for the troubleshooting performed on your watch @Keekers09. I checked with our Support team and I could confirm that a case was created. Please continue the communication with them.
See you around.
08-27-2021 09:27
08-27-2021 09:27
Make sure when you click on the Versa 2 in the Bluetooth setting that "Share System Settings" is toggled on if you have an iphone.
08-27-2021 16:13
08-27-2021 16:13
Same, i just deleted and redownloaded the app. The problem is that it happends 5 times a day (my fit bit is only 2 days old).
08-30-2021 12:40
08-30-2021 12:40
I did contact customer support but they stopped responding.
08-30-2021 12:40
08-30-2021 12:40
I will try that but it is really annoying to have to do that. hope yours gets sorted.
08-31-2021 10:03
08-31-2021 10:03
I've just seen this keekers?
is anyone responding to you??
