my first versa was replaced on Friday, set up as normal and then the last sync update was Sunday.
I've tried restarting, taking off the app, disconnecting Bluetooth, etc and still nothing. i get as far as the device been found and been able to enter a code on the app (as if setting up a new device again) and then it won't connect, just circles on that screen. I've turned off all other blue tooth devices. so frustrating. what more can I do?! I'm losing all my stats!
@Mariasimpo Please try this:
The trick here is to not pair in phone Bluetooth settings but rather let the Fitbit mobile app do that.
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure Always Connected and All day sync are enabled.
