12-18-2018 16:04
12-18-2018 16:04
My Versa suddenly stopped syncing. After I reset it will no longer connect to the app. Any fixes?
Best Answer12-18-2018 16:57
12-18-2018 16:57
@Nwilburn Phone model and OS? For now you can try this:
12-18-2018 16:57
12-18-2018 16:57
12-18-2018 18:47
12-18-2018 18:47
I’m having the same issue. It won’t sync and the versa won’t even locate the WiFi to try and reconnect.
Best Answer12-18-2018 19:54
12-18-2018 19:54
Thank you Marrrmaduke, I was having the same problems but i followed your instructions and it is now connected and downloading, Thank you again 🙂
Best Answer12-18-2018 20:17
12-18-2018 20:17
@Donnab05 I am happy it works, Donna! I recommend the whole procedure in the beginning, but when my Versa decides to misbehave I usually just forget it in the bluetooth settings, reboot phone and Versa and sync again. No re-install of Fitbit mobile app needed. I am on Android tho.
12-18-2018 21:03
12-18-2018 21:03
I'm new to the fitbit world, so still learning 😊 I also have an Android phone. My fitbit stopped syncing yesterday after doing an update so I done a factory reset and it just wouldn't connect so I checked the help Forum and found your instructions so thank you again
12-18-2018 21:09
12-18-2018 21:09
@Donnab05 You're welcome! Merry Christmas, Donna. 😊🎄
12-18-2018 21:12
