08-24-2022
12:59
07:07
08-24-2022
12:59
07:07
Hi. My fitbit versa wont turn on after the factory reset.I tried left&back button but no logo or vibration.
08-25-2022 07:09
08-25-2022 07:09
Hi there, @Max217. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
It seems like the Factory Reset might have drained the battery, but also that the battery may not be charging properly. With that said, please try the following steps:
Hope that helps.
Best Answer08-25-2022 07:09
08-25-2022 07:09
Hope that helps.
Best Answer09-09-2022 09:40
09-09-2022 09:40
I did try doing that but it still dosent work but it did show a 0% battery icon and it glitched out and i noticed a rattle in the charger and i ordered a new one but still no luck.
Best Answer09-10-2022 22:40
09-10-2022 22:40
Same with me it doesnt work.
What will i do now any suggestion
