08-17-2020
02:46
14:12
08-17-2020
02:46
14:12
My Fitbit Versa display isn't coming on. I've charged and tried pressing the Back+ lower button together but that doesn't seem to work either . Not sure what the reason is , it's only a year old. Need help here.
08-18-2020 14:13 - edited 09-24-2024 16:15
Hi there @Anchal, welcome to the Community Forums. Thanks for the details shared in your post about your Versa's screen behavior. I appreciate you've taken the time to troubleshoot your watch prior to posting here, I'll be glad to continue assisting you.
In order for me to better assist you with this, please confirm if you've tried the steps below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
I'm looking forward to your response, keep me posted.
08-19-2020 04:15
08-19-2020 04:15
Hi,
Thank you for your help. In fact, I tried your suggestions but I guess my watch display is gone cos I don't see anything on the screen even after charging it and turning it on. I know it's on as my alarm rang but there was nothing on the screen, I realised with the alarm vibration. Is the display replaceable?
Best Answer08-20-2020 07:42 - edited 08-20-2020 07:43
Hi there @Anchal, thanks for getting back and for the update. I appreciate you had followed the tips and recommendations provided above. Please note the screen is not replaceable. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know. 😉
