08-16-2021 19:19
08-16-2021 19:19
My Versa was working perfectly fine but now it won’t turn on. I tried charging it and I tried using the buttons to reset it but the screen is still black.
08-19-2021 11:47 - edited 10-25-2023 17:07
Hi there, @IsabellaMancini @Henny007. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Smartwatches before reaching out. I understand where your concern is coming from.
Since the restart you tried hasn't worked, please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Best Answer08-17-2021 00:46
08-17-2021 00:46
I’m having exactly the same issue this morning.
Best Answer08-19-2021 11:47 - edited 10-25-2023 17:07
Hope that helps.
