I've just brought a new versa. On Thursday .I have the Huawei P20 Pro. It will not work at all. I've tried since Thursday to do the update. It won't work. It just displays the logo. I've tried deleting the app. Reinstalling it. Restarting phone. Restarting Fitbit. Everything that's online I've tried. And nothing is working. So upset and disappointed. Just wondering if anyone else is having this problem. Thanks
@Jaydeevic1414 I am assuming you have never managed to set this device up. So, does it still display a message to download Fitbit app etc? Or something else?
Best AnswerHi, your phone is in the list of supported devices by Fitbit, so it should not be a problem to set it up to your phone. Since it is a new device, setting it up will also install the newest Firmware Version. This can lead to problems during the setup. Try this guide to setup your Versa with you new device and follow it to to the letter: https://community.fitbit.com/t5/Versa-Versa-Lite/Hassle-free-guide-to-update-your-Versa-s-firmware/t.... In this guide your setup will be done over WiFi instead of BT. Hope this guide is helpfull for you, and if yes, see my signature. Good luck!!
Best Answer@Jaydeevic1414 It means your tracker hasn't been set up yet. Your phone model is not supported, but some people on this forum have reported that they manged to make it work with the older version of Fitbit mobile app. I would suggest downloading Fitbit 2.74.2 apk file and installing it. You can google the instructions if you do not know how to do that. You will need to uninstall your current fitbit mobile app. Then perform the following steps:
