07-14-2019 17:52
07-14-2019 17:52
My versa want sync.....After master reset it just shows the Fitbit logo and flashes through different languages.
07-15-2019 00:26
07-15-2019 00:26
If you have done a factory reset then you will need to go through the initial set up again. In your app go into the account section and select "set up a device". Once the setup is complete it will hopefully connect and sync again. If not, the syncing issues may be caused by another problem. If this is the case, let us know.
Best Answer07-15-2019 04:48
07-15-2019 04:48
Best Answer07-15-2019 07:33
07-15-2019 07:33
As it's not connected to your account it won't show or do anything else until the setup completes. As you can't do that you might want to talk to customer support via contact.fitbit.com
