09-01-2020 20:12
09-01-2020 20:12
Versa is dead. I check app and computer and it shows battery at 50%. Screen is black. Put it on charger nothing, doesn't vibrate when I put it on. Made sure it was connecting to the pins. No lights on the back of watch. Tried cleaning as stated with rubbing alcohol. Nothing. Tried plugging charger into different places, plugs, computer. Nothing. Tried updating. Cant find Versa to update. Turned off and on my bluetooth connection.
09-01-2020 20:23
09-01-2020 20:23
Welcome to the forums!
Sounds like you have tried everything. Contact support to see what your options are. Use help link at top of forum
Wendy | CA | Moto G6 Android
