06-09-2021 22:59
06-09-2021 22:59
I’m so frustrated I have 3 versa and none of them are working properly 1 not syncing, 1 not even switching on and last one frozen screen, can any of them be repaired as I think all of them are out of warranty, or do I just upgrade???
06-10-2021 00:44
06-10-2021 00:44
Try taking the best one [though the other faulty ones may be resolvable] and concentrate on solving its problem.
You can see the pictures in this link
06-10-2021 00:44
06-10-2021 00:44
06-13-2021 04:50
06-13-2021 04:50
I’ve tried all of that and still not syncing properly, just wondering if it’s worth upgrading or looking at alternative supplier.
Best Answer06-13-2021 05:00 - edited 06-13-2021 05:00
You can also try removing the device from your account, clearing the cache and force stopping the App. or reinstalling for iOS.
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
Or for IOS uninstall/reinstall the Fitbit App, and redo all notification setup. |
Then shutdown the watch and restart the phone again, restart the watch on the charger and in the Fitbit App do + Set up a Device.
Note. The original Versas are normally the most reliable currently, if you can fix it so much the better.
