Versa2
ANSWERED
My versa2 is dark and now it will not connect .I could barely see smothering even the time.
1 BEST ANSWER
Accepted Solutions
@SiskSiskg - chat via the Fitbit App, click profile photo, Help support, Contact Customer support. They may take you through a factory reset to check if it's faulty.
If under warranty, 1 or 2 years depending on country law, take it back to the place you brought it for replacement with a new one.
5 REPLIES 5
Hi @SiskSiskg - it may need charging if you see nothing
If you see it dim, out of sunlight, try pulling down from the top edge once and then again and click on the 2 white bars to get to Quick Settings and make sure sleep is not enabled because that dims the watch.
Author | ch, passion for improvement.
It was fully charged and it is still dull even in the house, I changed the face on my versa 2too.
I don't think my versa2is under warranty because I have had it shortly after it came out and I don't remember where I bought it.
My versa 2 died yesterday ,I was at a water park and I couldn't even see the time it was black nothing
