09-10-2022
05:46
13:24
09-10-2022
05:46
13:24
My verse 2 will no longer track my heart rate or sleep. The settings are normal and haven't changed, is there a simple fix or is it time to buy a new watch?
I moved your question to the Versa community forums. Someone should be able to help you here.
Gordon
Hello @Klorissa1821
Can you check to make sure you haven’t accidentally disabled the heart rate? The screen is small and sometimes accidentally taps can happen. You need the heart rate enabled to of course track your heart rate and your sleep.
Let’s check the settings. Go to your clock face and swipe left to get to your settings (gear wheel). Tap on the settings then scroll down and find heart rate. Is it enabled. If not enable it then sync your Versa 2. If it’s already enabled try disabling it, sync your averse 2 then enable it again. Follow up with another sync so that your Versa 2 will accept the changes.
If the issue persist try restarting your Versa 2. Just press down and hold the button on the Versa 2 until you see the Fitbit Logo then release the button. You should feel it vibrate letting you know the restart is complete.
😃 Hopefully that will get your heart rate tracking again as well as tracking your sleep. Please come back and let me know if this answered your question and helped resolve the problem.
Best AnswerHello again @Klorissa1821
Is the green light on the back of your Versa 2 on at all? Some users have resolved this by changing their clock face going through the Fitbit App. It’s certainly worth a try. Here’s how: https://help.fitbit.com/articles/en_US/Help_article/2311.htm
If restarting your Versa 2, toggling on and off your heart rate or changing your clock face doesn’t seem to resolve the problem I’d contact Fitbit Customer Service. You can contact them here: https://myhelp.fitbit.com/s/support?language=en_US. I find calling them directly the most convenient but Live chat is a great option as well.
I’m hopeful that changing the clock face might do the trick. If not maybe Fitbit Customer service can help sort it out for you. Let me know how it goes.
Best AnswerDid you ever get this figured out mine is doing the same thing. I have reset it checked for updates. Any ideas?
Best AnswerI did and nothing has worked. 😭
Best AnswerI’m so sorry @AshleyWinter ☹️ I can only suggest calling Fitbit Customer Service using the link above
Best AnswerI am currently having same issue. I opened a case but am waiting to hear back. They originally had me go through resetting to factory defaults and such, but think it's probably busted or something. I'm guessing they'll try to say to buy a new one since I've had this one over a year. My HR is currently frozen at 57, was 55 before last reset, and 110 before the reset before then. Seems random when it freezes, but never changes once it does.
Best AnswerThe same thing happened to me. My Versa 2 just stopped tracking heart rate about two weeks ago. I tried everything suggested here and did the customer service chat twice (factory reset, etc.) but nothing worked. Mine is about 18 months old so they said it was out of warranty but they emailed me a code for 35% off a new device except it's not valid on any of the new devices. My only option is to get another Versa 2 which, according to the forums, has stopped working recently for a lot of people. Disappointing outcome so I'm going to look at different brands.
