Hi, if you think my post really helped you, see my signature. Thanks.
Hi, go to the settings of your Versa, press it and the first thing you will see is the brightness of your display. The default setting is either normal or automatic, but you can set it to Maximal when you go outside.
What is your brightness set at?
From clock face, scroll right until get to 'Settings'. Tap that, then scroll up or down to 'Brightness'; tap to choose dim, normal, max, or auto. I find Auto works well, adjusting to ambient light conditions.
