Viewing screen
ANSWERED
I cannot see anything on my Fitbit when I am outside because of the sunshine- how do I change that so I can read the time outside
1 BEST ANSWER
Accepted Solutions
Hi, if you think my post really helped you, see my signature. Thanks.
5 REPLIES 5
Hi, go to the settings of your Versa, press it and the first thing you will see is the brightness of your display. The default setting is either normal or automatic, but you can set it to Maximal when you go outside.
What is your brightness set at?
From clock face, scroll right until get to 'Settings'.  Tap that, then scroll up or down to 'Brightness'; tap to choose dim, normal, max, or auto.  I find Auto works well, adjusting to ambient light conditions.
When I touch settings all I see is select up to 7 stars to track- nothing about brightness
Sent from my iPhone
Thank you so much - I found it and it was on min
Sent from my iPhone
