I've tried several fixes that have been mentioned on other posts... but have had no luck!
I've tried:
I see all the other options (Clock Faces, Apps, Media, How To Use, and Accessories), but no Wallet.
Also, to note, I am in the United States.
Welcome to the Forums @minacosentino! Thanks for sharing the steps you performed and all the research you have done before posting here.
Please notice that some versions of Versa include a built-in NFC chip, which is the technology that lets you use make payments from your watch. To find out if your watch supports this feature, check the back of your watch. Fitbit Pay should be is listed in the text surrounding the heart-rate sensor, if you can make payments from your watch.
To read more about this feature, you can take a look at the help article What should I know about Fitbit Pay?
I hope this helps! 🙂
Best AnswerHello - my watch does say fitbit pay, I also tried all the steps (reinstall etc) but the wallet tile doesn't show up and I don't see a way to set it up. thanks!
Welcome to the Community Forums @jhoward319! Thanks for letting me know that you Fitbit Versa has Fitbit Pay. To open the Wallet, from the Fitbit app dashboard follow these steps:
Wallet
I hope this helps, keep me posted! 🙂
Weren’t only the special editions supposed to be able to pay using the watch?
because I have the normal one. (That costed 199,- ) And on the back of mine it also says Fitbit pay..
I have a new Versa SE which I specifically got to use the Pay function. The Wallet isn't showing up for me either and have tried unlinking/relinking the versa as well as reinstalling the fitbit app. Super frustrated!
@madelief @VolcanicGlass @Gianisxx Europe and Australia get NFC (Fitbit Pay) with base models. My Wallet tile didn't appear until like 3 or 4 days ago, it's just a matter of being patient, it's rolling out slowly.
I went through fitbit tech support and they ended up agreeing that something was wrong w/ my watch and authorized a return+exchange for a new one. Sent my watch to them last week and now I'm waiting for my new watch to arrive (it's like a 2 week process
Hi everyone! Awesome help @taijitu! Thanks for sharing this information @madelief. I hope you are enjoying your Versa.
@VolcanicGlass I appreciate the feedback about Customer Support. I wanted to assure you that we take into consideration all the comments provided by our users to continue improving your experience.
@Gianisxx Please confirm that you have followed the suggestions on my previous post, or the instructions on this video:
I look forward for your reply! 🙂
Best AnswerSame here, Wallet tile not appearing.. hope it's temporary issue as @taijitu said and it will appear eventually.
When contacted support about it, just received somewhat standard reply giving links to check supported banks. But the was not even the issue, the issue was that the Wallet tile does not appear so I don't even have a chance to set up a bank card ( I have from 2 different countries/banks).
Given how it seems to be affecting a lot of Versas & there's no answer from fitbit about why, I'm not that confident to be honest that my new one will be any better...but I'll let y'all know!
Thanks for stopping by @s_lv_pt! I appreciate that you have your experience with Versa and
Support. Sometimes this might have an easy fix, if the Wallet is not appearing on your Versa you can try the suggestions on this post Wallet not working on versa. Or, if it's not appearing on your app you can try to log out and reboot your phone. Once your phone is up log back in. If this doesn't, please let me know so I can be of more help. 🙂
Thanks for sharing your feedback @VolcanicGlass! I appreciate your feedback for the Fitbit environment, customer service, platform and devices. I'm sure that if you need further clarification about your case resolution support will be very happy to continue assisting with this. 😉
Catch you later!
Best AnswerThank's @LucyAP I've tried rebooting etc, didn't work.
In later responses from Support I was told that Wallet tile is location based, so basically, if I am not in country of the bank which is supporting Fitbit Pay, I can't even setup a card, even if I have the card/bank that is supported but I'm currently in other country that doesn't have supported banks. The Wallet tile will simply not appear if you're in country that doesn't have supporting bank, doesn't matter if you have a bank/card from other country that has, for Setup you need to be in country of bank. Was told it has to do with some authorisation issues with bank or smth like that.
With all that said, I just have to wait till country I am currently has approved bank or wait till I'm traveling to one that has to set it up.
Edit: aa, was told also, that simply changing location in settings manually won't make Wallet tile to appear, I would have to be physically in other country.
i wouldn't necessarily blame it on bad support, there's just really bad communication between them, a lot of support agents actually have outdated information so it's hard getting through. i'd just say be patient, mine appeared later completely randomly, i didn't have it at first either
Best Answer@taijitu well thanks, but to me bad communication is equal to bad support, given the fact that communication is the way how you get the support. Oh well, just have to wait and see how it develops from now on.
