07-06-2019 10:25
07-06-2019 10:25
I don’t quite know what I did but I have a continuous warning message saying
This app requires the ‘internet’ permission to be granted
Even resetttmy verses won’t stop it.
Any help is appreciated.
07-06-2019 15:40
07-06-2019 15:40
Try uninstalling the app, rebooting your phone and re-installing it again.
07-07-2019 02:38
07-07-2019 02:38
07-07-2019 04:02
07-07-2019 04:02
I am having the same issue... Just started flashing the message and will not stop. I cannot reset the phone. Tried removing and reinstalling but no change. Seems it is a "just after warranty" issue (ended in June).
07-07-2019 04:08
07-07-2019 04:08
It’s very frustrating. Fortunately mine Fitbit is still in warranty, so will be contacting them tomorrow. I’ve uninstalled and reinstalled the app too. Can’t do a hard factory reset because of the warning issue as I can’t get into the settings.
07-08-2019 07:09
07-08-2019 07:09
Hi, I’ve phoned Fitbit customer service and they helped me sort the problem. Have you used a watch app on your versa? If so I can help you sort your issue. If it was a different app then I’m not sure but recommend you phone customer service for support.
07-08-2019 07:20
07-08-2019 07:20
Hi,
Yes, I was updating my watch face when this occurred. I chatted with Customer Support and they could not figure it out....
Any help would be appreciated.
Mike
07-08-2019 07:30
07-08-2019 07:30
07-08-2019 08:02
07-08-2019 08:02
Worked Great. Thank you for sharing.
Mike
07-08-2019 08:17
07-08-2019 08:17
