09-08-2019 03:30
09-08-2019 03:30
I recently updated the versa app and it said once updated you can’t go back. Unfortunately the new app only has one design which is analog and I want mine in digital. Anyone managed to get there versa back to original settings. Typical when update gives you less options than old versions. Should have left it alone.
09-08-2019
03:53
08:57
09-08-2019
03:53
08:57
Hi, @Racoonicus , I think there must be some confusion here... I have just checked both iOS and Android app and I have dozens of digital clock faces to choose from.
Which app are you using? Could you post a screenshot?
I would recommend deleting and redownloading the app.
09-08-2019 04:23
09-08-2019 04:23
