Water Damage!?!?!?
So, I wore my watch while in shallow water, for a short amount of time, and now it won't turn on. I've tried holding down all three buttons for an extended amount of time, with no response. Then, I turned over the watch and in the heart rate scanner thing, I saw small air bubbles, like there is water inside! I'm really scared I've broken the watch!!!!! Help!!!!
3 REPLIES 3
Hi @BELLAC26006,
My sister did the same thing with a non-water resistant cell phone and it worked wonders.  You will need a Ziploc bag, the Versa in question, and white rice.  Fill the bag with white rice and put the Versa in it.  Leave it in there for a day and then it should act as though the watch never even went in the water.
Rice is a starch, so it should dry out the water from the watch.  Once it's dry, dry the Versa with a towel and give it a charge.  See if it will connect to your phone and if not, contact Support.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
Thankyou!
@DramaQueenDiva
Hi, thanks for that, I've tried it for a while now, but sadly it hasn't worked.  Thanks anyway!
