Water logging issue after update
Has anyone been unable to log their water from the watch after this recent update?
Everything was working perfectly up until last weeks update! I cant track my water, see totals and have syncing issue with the app. I've reinstalled the app, restarted and paired/unpaired the versa multiple time. Nooooothing is working!! So frustrating that I've had this tracker for 7 days and I'm ready to return it cause it's not working right.
Is there a fix coming soon for this or are we all stuck like this??
4 REPLIES 4
Definitely having problems with water not tracking. Not matter if I input consumption in the watch or mobile app, it is not logged. All other apps are syncing okay though. Sorry you're having so much trouble. 😞
I have the exact same problem.  It started behaving that way as soon as I updated the firmware a couple days ago.  It is annoying, because i really liked the convenience of adding my water directly on the Versa 2.
Also unable to log water on my Versa. Still works on the app, but not very convenient. Hoping this gets fixed soon.
Thanks Ladies for letting me know that I'm not alone lol
I love the tracker and I was so excited to use it. I've gone as far as factory reseting to reinstall the update to make sure it properly installed.. .but still nothing. This is a developer issue because every time in the past I updated my old tracker's firmware something wasn't working right, and then patches/fixes were pushed thru to fix it. I just hope this is fixed soon.
