03-07-2019 12:03
03-07-2019 12:03
I have synced. I have put on current location. It's on all-day sync. I downloaded the Accuweather app on my phone. Synced again. The town names come up but nothing else. Disappointment.
03-07-2019 14:01
03-07-2019 14:01
Hi, sorry to read that your weather app is not working like it should. Downloading the Accuweather app is not the problem, cause the Versa uses Accuweather as it's standard API. What you can try to do is:
1. Go to Apps - My apps
2. Scroll down untill you see the Weather app
3. On the right side next to the name of the app, you will see the settings icon.
4. Press that and press add city and enter manually the same data of your current location. F.i, when your current location is London UK, after having pressed add city, enter just London, press search and when London, UK shows, press OK.
5. Restart your Versa after that.
Works fine for me. Good luck.
Best Answer03-07-2019 14:08
03-07-2019 14:08
I don't see instructions for restarting it.
Best Answer03-07-2019 14:11
03-07-2019 14:11
Press and hold the left and right lower buttons together untill you see the Fitbit logo and release the buttons.
Best Answer03-07-2019 14:12
03-07-2019 14:12
I found it. It worked. Thank you.
Best Answer03-07-2019 14:24
03-07-2019 14:24
You're welcome, see my signature!
