Weather App Stuck
My weather app is stuck on Celsius and I can't get rid of it. The settings are set to Fahrenheit, but it still shows as Celsius. I have tried removing the Versa 3 from my app and I have tried resetting it. Neither of them has worked. Any idea on how I can stop this?
4 REPLIES 4
From phone app 'Today' screen':
Profile pic > Versa 3 > Gallery > Weather > Settings > Unit
Thank you so much! It wasn't exactly where you've mentioned though (maybe it's different because of iOS and Android, which I have iOS). I had to go to the Gallery>Apps>By Fitbit>Weather>Settings.
But by following your directions, I've found it. I didn't even think to look in the gallery. Again, thank you so much!
At least on mine, after I choose 'Gallery', there are 2 ways to get to 'Weather' app.  I thought I had described the quicker way, but either works.  Within Gallery, there are 3 tabs at top, <your tracker model>, 'Clocks', and 'Apps'.  By going to 'Apps' tab, you had to filter through all available apps.  By sticking with the default tab <your tracker model> (which I left out to simplify since it is the default), it show only the apps already on your device.
Worked for me too.
