Hi I just just switched from a Blaze to a Versa.
When I go to set up my notifications through my Versa on the app is it only showing a small number of apps I have installed on my IPhone.
I cannot even select whatapp from the list to set up the notifications.
How do I get All the apps on my phone to show in the list in order to select them?
I have checked all my settings in my phone and they are all set up correctly. And they all worked Fine on my blaze.
Thanks
Whatsapp or other apps should appear once a notification is sent to your phone with the Fitbit app installed. If you have received a notification in the mean time you could try to refresh the apps by pulling down the list until the refresh happens.
if this isn’t working I hope someone else has the solution.
