06-30-2022
16:29
17:50
06-30-2022
16:29
17:50
My fitbit has been charging for a few hours. It won't turn on and the back isn't blinking. It's absolutely doing nothing. Anyone have this happen and know a quick fix? I've only had it for a couple of months.
06-30-2022 19:11 - edited 06-30-2022 19:12
Hello @weezyrn
You can “try” to restart your Versa 3. Just press down and hold the Versa 3 button until you see the Fitbit Logo then release the button. You will feel the Bersa 3 vibrate indicating the Versa 3 did indeed restart. Hopefully this works. If not, because your Versa 3 remains completely unresponsive, I’d suggest calling Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US
Please let me know how it goes
06-30-2022 21:14
06-30-2022 21:14
Hi @weezyrn - if starting it with the button does not work the battery may be flat and it's not charging.
The main reasons for that can be the 4 contacts on the watch need cleaning or commonly the charge cable is faulty - see the steps to do in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
