I am in school to become a veterinary technician and I currently have a Charge 3. I would like a fitbit that I can use to take heart rates and respiratory rates with, which would mean I need a fitbit with a second hand face and a fitbit that will stay lit while I count these measurements for at least 30 seconds. Will the Versa or Versa 2 be able to do that for me?
Thanks!
There is several watch faces that will work for you, some designed specifically for medical personal.
Several are designed to stay on with a tap. The watch can also be set for an on time of 60 seconds.
The built in stopwatch can also be set to stay on.
@Rich_Laue There is an option to set for 60 seconds on my charge 3? I would prefer to not have to press anything to keep it lit, but I can try and see if it will work.
Best AnswerThe 60 second setting is not available on the Charge 3. The Versa watches have clocks that will stay on all the time, but will use more of your battery. You may need to change every two days or so.
@Den_in_USA I saw a face last week that with a tap, the face will stay on, and a second tap will switch it back to normal.
A user could set the always on for their work schedule, if their hours don't change.
Best Answer@Den_in_USA is there an option to only make the versa stay on for maybe 30 seconds? Or is it always on or always off, no middle ground?
Best AnswerOn the versa the setting for in time is 10, 15, 20, 45, 60 seconds.
An off would prohibit the user from being able to reed the time.
