Wristband replacement
ANSWERED
Hi so I’ve had my Versa for about a year and after try myself many times to replace my wrist band going to bestbuy to ask for there help I have still not be able to replace the wristband my current one has ripped and I have not been able to use my watch at all I’m extremely disappointed in a product that promised me durability. Any help or advice is appreciated!
1 BEST ANSWER
Accepted Solutions
Hi, @Jackson3212 , the Versa has a fairly common wristband replacement system with a pin.  I am astonished that Best Buy could not help you with this. I would recommend purchasing a new band (do make sure it is compatible) and trying Best Buy again.
I have several bands that I swap out with my Versa.  It is a little fiddly, just like any watch band, but certainly doable!
Alternatively, as it is a standard pin system if you have a friendly local jeweler shop they might also be willing to help you if you bring in the band.
I hope this helps.  Welcome to the forums!
2 REPLIES 2
Are you saying that you can't get a replacement, or that the replacement is hard to put on?
