03-02-2020 11:45
03-02-2020 11:45
I just upgraded to a Versa 2 from an alta hr, hoping to be able to get better information, not less! I manually add my workout when I'm finished--always worked fine with alta hr. My heart rate, steps, calories burned, etc, would be calculated and recorded. Now, with Versa2, I am not able to get this data. I am so disappointed! I have read through the help logs, and the help notes to no avail. Should I return this watch and stick with alta hr???
03-02-2020 13:20 - edited 03-02-2020 13:20
Welcome to the forums!
This is a known Issue for iOS. Follow this thread for updates
But why not use your device and record it? You can have up to 7 shortcuts that can be listed on your device.
How to customize exercise modes
Once it sync's they will show on your device and then all you need to do is scroll to the exercise screen select the one you want. Hold the Button down to start then hold in again when done to stop it
I have Workout Mode also on mine for exercises not listed. Then I can rename to what I want once it syncs. You might have top set up some custom ones and you can find that at the bottom of the exercise tab
Wendy | CA | Moto G6 Android
Best Answer03-02-2020 13:26
03-02-2020 13:26
