@Mrbean The feature that auto-tracks certain exercises is called SmartTrack. Fitbit has many older trackers, still in use, that don't have either connected or built in GPS. SmartTrack lets these users auto-track certain exercises. It is also really useful on trackers that do have GPS capabilities. Many, if not most, of my walks/runs/bike rides are familiar routes. I don't need a map for each one.
Laurie | Maryland
Best Answer@Mrbean -
First off, you can leave auto-track on and still initiate an exercise app "walk" and get the map.
The reason you do not get a map on an auto-recognized walk (sometimes referred to as SmartTrack) is that your device doesn't recognize a "walk" as such until you have steadily walked, with minimal breaks, for more than 10 minutes, minimum - that is a setting that you control, as I am sure you know. And you don't want assisted-GPS running 24/7 just in case your meandering around happens to reach the defined minimum. Your device and phone batteries appreciate it, I'm sure.
Bottom line - if you set off with an intent to perform a walk, trigger a walk with your device's exercise app and get your map. But, just in case you happen to do a little bit more tooling around than expected, let the device auto-recognize the walk - you will still get credited for the walk but miss the map.
There have been a few times that I have been out doing yard work and a neighbor was walking by and asked for a "short" conversation about their computer system at work - well, short turned into a 15 minute walk around the neighborhood and 3/4 of a mile - auto-recognized as such, as I noticed later - and I went back to looking for weeds in the yard.
Home this helps.
