01-01-2020 12:06
01-01-2020 12:06
Is it possible to connect a Versa 2 to a MAC computer using Fitbit Connect?
01-01-2020 13:44
01-01-2020 13:44
Yes, See second paragraph HERE.
Best Answer01-01-2020 14:13
01-01-2020 14:13
@ttt-123 @SunsetRunner I believe that the correct answer to this is no, you cannot sync a Versa 2 using Fitbit connect. From what I remember reading, and I wish I could find the source, a Versa 2 will only sync with a compatible Android or iPhone. A Versa 2 will not sync with the Windows 10 app on a PC. The source is different from the link supplied by @SunsetRunner .
I hope I am wrong about this.
Laurie | Maryland
Best Answer01-01-2020 16:43
01-01-2020 16:43
Laurie, my reference above says differently and it is the latest "compatible device" info we have available. I've read somewhere that you can't use a Windows 10 computer to sync a Versa 2 but that's what I use and it works fine.
