Hi, assuming that you mean that your activities are not shown in the Fitbi app, try the following:
1. Logout of your Firbit account
2. Deinstall Fitbit. Do not remove.unpair your Versa from the Fitbit app
3. Restart your phone and enable BT
4. Reinstall Fitbit app. This also makes that you have the latest version of it.
5. Login to your Fitbit account
6. Sync your Versa with your phone and see if the problems are solved. Good luck!!
@jac12 wrote:hi
just synced and my activities over weekend are not showing.. can anyone help?
thanks
Have you really synced @jac12 ? When you two on three Versa Icon, the page that opened up will tell you when the list tracker synced.
@SunsetRunner your sounding like a broken record, copy pasting the exact same post to get points
