data saved on watch?
Hi! I have a versa. I didn't sync for 2 weeks because I was out of the country. I sync'd it now and only shows today's activity. Is that data from the last 2 weeks gone? Or is saved on the watch? Can i get the data somehow?
1 REPLY 1
From What should I know about traveling with my Fitbit?
  • Most trackers store up to 7 days of detailed minute-by-minute data. If you have a Fitbit Alta™, your minute-to-minute data is stored for up to 5 days. If you wait longer than 7 days (5 days for Alta) before syncing, you may only see the most recent week's detailed data.
  • Summary data (calories, distance, steps, and floors) will be stored for 30 days. If your tracker measures heart rate, summary heart rate data will be stored as well.
