At some point I set my sleep setting to sensitive and I would like to set it back to standard, and can't remember where that is done
Thank you, I followed that link to the gear in the upper right hand corner of fitbit.com and found where I had originally changed it to sensitive, though like you said, I don't think it makes a difference with my watch, it was bugging me though that I couldn't find where I had originally changed it.
See What is the difference between the normal and sensitive sleep setting?
But note this sentence: "Note that if you use a Fitbit device with heart-rate tracking to detect your sleep stages, this setting doesn't apply."
Best AnswerThank you, I followed that link to the gear in the upper right hand corner of fitbit.com and found where I had originally changed it to sensitive, though like you said, I don't think it makes a difference with my watch, it was bugging me though that I couldn't find where I had originally changed it.
Really? If my Ionic is tracking my heart rate, it will not record sleep properly?
My sleep recordings don’t start till hours after I know I have been asleep, and this has been going on for two years, without being able to find a solution.
