01-15-2021
07:34
08:54
EstuardoFitbit
01-15-2021
07:34
08:54
EstuardoFitbit
Hi guys, don't know if you can help but on my fitbit app when I go on my profile then tap my device (versa 2) I only have the apps alexa, clock, apps, media, wallet and how to use. Just wondering how to get accesories so I can reply to texts from my fitbit. Much appreciated if anyone knows, please reply. Thanks.
If you click your profile picture, then versa 2 and scroll down you should see notifications. From there you would be able to select which notifications come through on your versa 2.
Best Answerthanks for replying yes i see that but where spotify, apps, alexa etc are there should be something that says ACCESSORIES which there I turn on notifications to REPLY TO TEXTS. thanks anyway though
Best AnswerI think you're mistaken. That option is for buying accessories.
What you need is the option I suggested. You should see all apps from your phone in that menu and from there is where you set notifications for emails, Spotify etc....
