12-01-2018 03:51
12-01-2018 03:51
Hello,
I got my Versa yesterday with all updated Firmware. My versa unable to show me the Accept Call notification symbol. There is only Reject call notification at top but nothing for accept.
Any idea how to fix or Troubleshoot that?
I am using Android Phone. Oppo F5
Looking forward the Help
Thank You
12-01-2018 05:40
12-01-2018 05:40
I don't believe the Oppo F5 is a supported device. So you might be able to use the tracker, but some features may not be fully available to you.
You can find a list of supported devices here: https://www.fitbit.com/devices
12-01-2018 22:49
12-01-2018 22:49
12-03-2018 11:58
12-03-2018 11:58
@Kamran123 Welcome! It's good that the community is growing! Sorry to hear that you can't accept calls with your Versa. As @Heather-S said your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
Best Answer06-28-2019 08:46
06-28-2019 08:46
I am having the same issue. How ever I am using a Samsung S8 which is compatible. I have updated everything tried resyncing. etc etc. How can I get my versa to give me the ability to accept a call instead of only seeing the reject option?
