02-21-2020 15:39
02-21-2020 15:39
My versa 2 voice rely to texts was working fine - all of a sudden it won't work - I can tap the yes and that sends but cannot record a reply to a text anymore.
		02-22-2020
		00:48
		03:29
		02-22-2020
		00:48
		03:29
Hi @Joey18 good to see you in the community.
Can I ask which mobile device you are using? I would first suggest restarting your Versa 2 (by pressing and holding the button for 10 seconds) and also your phone to see if that solves the issue.
		02-22-2020
		00:48
		03:29
		02-22-2020
		00:48
		03:29
02-22-2020 07:38
02-22-2020 07:38
Thanks so much N8teGee- I have a Samsung Galaxy S7 - I did try that first- then I rebooted the Versa 2 like you said - I think I am good to go ! thanks again
07-25-2020 22:01
07-25-2020 22:01
I am having the same problem. I've done everything to make it work. Un installed, attempted and update nothing.
08-16-2020 16:55
08-16-2020 16:55
I am having the same issue. The auto reply feature still works but not the voice reply. I have restarted the Fitbit and that did not fix it. So frustrating!
08-22-2020 07:16
08-22-2020 07:16
I did get it to work finally- first I restarted my phone - android - and then I hold the button on my Versa 2 for 10 seconds which I think re boots it and it works - also if your phone is syncing - during that time voice reply will not work - the voice reply stops working on occasion and I have to do the above again - hope this helps
08-22-2020 07:29
08-22-2020 07:29
 Best Answer11-23-2021 12:08
11-23-2021 12:08
Restarted phone and Fitbit. Uninstalled the app, unpaired the Fitbit from my phone.... Started all over. Set everything up, checked permissions and accessibility.... All seems correct, but the voice reply WILL NOT WORK.
11-23-2021 13:48
11-23-2021 13:48
I finally got mine to work - I can't remember how - did the unpair and then paired again -afrer you restarted your phone did you hold the button for 10 seconds so the watch rebooted? I think I had to do it quite a few times to get it to work - phone first then waited and then the Fitbit
