03-23-2020 05:28
03-23-2020 05:28
versa will not sync on android for a while until you manually sync it
03-24-2020 07:19
03-24-2020 07:19
But it does manually sync @SomeKid
Go to the phone settings, apps, fitbit, power management and disable for the Fitbit app.
Best Answer03-24-2020 07:19
03-24-2020 07:19
Best Answer03-24-2020 20:37
03-24-2020 20:37
will that disable the all day sync then.. or will it enable the all day sync?
Best Answer03-25-2020 06:13
03-25-2020 06:13
It simply keeps the phone from shutting the Fitbit app off when the App gets moved to the background.
