Hi there,
when I‘m on the Elliptical, hands moving as I walk, Fitbit does not count properly the km aswell as the steps.
expl. 40min walking and I just get 1500 steps, 1km and 150 kcal - Elliptical shows about three times more on km and kcal (steps are only counted on Versa). Any suggestions on that problem?
If your KM refers to distance, then unless you give Fitbit the imaginary stride of the elliptical the distance will not be correct.
When it comes to kcals have you setup your stats correctly on both the elliptical and Fitbit?
Best Answerthank you for your Information.
Yes, exactly I do mean distance. Hmmm, how do I do this? I usually set my time and then aim for a goal distance - I can‘t choose a route.
Concerning the kcal, I have put in the same information on both - just checked. Maybe you do have an idea?
