Able to create a custom meal and indicate number of servings
I would really like to be able to build a recipie and then indicate how many servings it makes and how much I ate and see nutritional break down by servings too.  I think it would way easier than trying to enter all ingredients then when its time to eat the leftovers I can just add the recipie serving.
Moderator Edit: Clarified subject and updated label
757 Comments
LordHarry
First Steps
Agree!!! Please add # of servings and also just the meal needs to show up in the log not all the individual components.
DavideFitbit
Moderator Alum
Moderator Alum
Hi @Nrowden, thanks for taking the time to share your feedback about the possibility of creating a recipe on the Fitbit app. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
Thank you again for your participation in the Community.
Nrowden
First Steps
Ok, thanks for there response and information. I noticed there are some requests for this feature dated way back in 2014. Other fitness apps have long since added easier ways to track meals and recipes. I wonder if Fitbit will ever get around to it?
Thanks,Natasha Rowden
Sent from AT&T Yahoo Mail for iPhone
nicky1910
First Steps
I would really like it if your app developers could take a look at dietary apps like myfitnesspal, Noom, Mealime and integrate some of the facilities that they have i.e. importing recipes, being able to portion meals, and doing this from the app instead of the desktop. I do not eat processed food or restaurant food regularly and it's a ball ache having to open my laptop to add each of the meals that I cook as well as trying to work out how to add the correct portion of food. Ideally I would like to have everything in one app rather that having 2-3 apps
YoBubba
Recovery Runner
Hear hear!! We've been trying to get them to do this for eons now. Really, I was still working back then; I've been retired now for 9 years!!! I feel like we're texting to the wall. Hello? Anybody out there that works in development at Fitbit??? Woohoo!  We're over here!! (Granny jumping up and down getting steps in) 🙂
I gave up. I'm using cronometer. Haven't touched processed food since I retired. And I'm only using Fitbit for the steps and sleep logging.
tmjliberty
Jogger
It would be great if favorites and recipes creation were an option for food logging. It be helpful if we could type in the barcode manually if it wont scan to log info.
Ljelo1
First Steps
With MyFitnessPal making their bar code scanner a subscription service this more important than ever. Ali I would like to export my recipes from MyFitnessPal to Fitbit.
PaulaLyn
First Steps
Given that there has been ZERO movement on this front and the fact that the screen on my fitbit has completely died, I'll be moving away from fitbit.
nicky1910
First Steps
Does anyone know if apple offer this feature on their smart watches, I think I will be following you when my watch dies. 🙄
Sent from Yahoo Mail for iPhone
Mishamae
Stepping Up
I use to be able to enter my recipes into my fitbit app. Now that option is not available and I have been told I have to integrate another program into fitbit to do this. I think Fitbit should make it easier for users to use their own recipes.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @Mishamae, thanks for sharing this suggestion about being able to create your own recipes on the Fitbit app with us. Because this idea was already requested in the Feature Suggestions board, I’ve moved your post here. This will help us to make sure the suggestions don't get confused, or split a popular vote. Please click on the thumbs-up to show your support.
BASILCHIVES
Strider
When a multi ingredient meal is created, have a box to input the number of servings, so when selecting the meal, 1 portion can be selected so the entire meal doesn't get logged
redfoot
Stepping Up
When logging any Food Entry you have the opportunity to edit the portion size. Give the app the ability to do simple arithmetic by inputting a simple expression. E. g., a standard medium baked potato weighs 173 grams. My potato weighs 237 grams. Let me replace the portion size (1.0) with the expression 237/173 Enter. The app calculates 1.3699.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @BASILCHIVES, thanks for taking the time to share this suggestion about adding the option to log servings of meals on the Fitbit app. I've moved it into a similar request. You can learn more about how Fitbit decides what suggestions get released in our FAQs. Click on the thumbs-up to show your support.
Thank you again for your participation in the Feature Suggestions Forums.
SirRookie
Jogger
Agree the “create a meal” tan feature currently allow us to enter a recipe with the ingredients you used to cook a meal. However, what it does allows to do is to enter how much of that meal you actually ate when logging it. Therefore, every time you ate a different amount of the same cooked meal you need to add the meal and update the values off all the ingredients of that meal by dividing it by the amount ate. If the recipe make 2 servings and you ate 1 then each ingredient is .5 of the recipe.
When logging food the mobile app should allow entering a meal that has been alredy defined.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @SirRookie, thanks for taking the time to share this suggestion about allowing logging meal on the Fitbit app or fitbit.com Dashboard. I've moved it into a similar request. You can learn more about how Fitbit decides what suggestions get released in our FAQs. Click on the thumbs-up to show your support.
day2daydro
First Steps
Currently, if I want to Create a Custom Meal, I have to go to the Fitbit Website, log in etc. to Create a Custom Meal which will then Sync and download to the app. I'm not paying your Premium Fees to have to go to 2 places. This should be added to the app LIKE IT WAS BEFORE YOU STRTED CHRGING FEES for this "better" app!
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @mortonboots, thanks for taking the time to share this suggestion about adding the option to create meals on the Fitbit app. I've moved it into a similar request. You can learn more about how Fitbit decides what suggestions get released in our FAQs. Click on the thumbs-up to show your support.
Bmet
First Steps
Similar to the “add meal” function, you should be able to enter all the ingredients and then divide it by the number of servings.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @Bmet, thanks for sharing this suggestion about being able to add your recipe on the Fitbit app and indicate the number of servings with us. Because this idea was already requested in the Feature Suggestions board, I’ve moved your post here as this will help us to make sure the suggestions don't get confused, or split a popular vote. Please click on the thumbs-up to show your support.
jecie123
First Steps
Looking for a recipe builder in Fitbit so I can indicate my own portion of a total recipe.
Can't seem to find it. Essential for at-home cooks. Thanks!
Lndsywllms
Jogger
I came to suggest the same thing as jecie123. I know that on the desktop dashboard we can enter custom recipes, but to my knowledge after that you can only log the ENTIRE recipe.  but we should be able to log a FRACTION of that whole recipe as a portion we ate. Maybe I make the recipe the same everytime but one day I eat 1/5 of the batch and the next time I eat 1/4 of the batch. So as it is, it's not incredibly helpful for my purposes
Jen53190
First Steps
I wish this was a feature. Or if you scan barcodes for 3 things to build a meal- like my lunch meat, sandwich thins, and some mayo or dijon mustard when I add a food to their catalogs.
indygeekmom
Jogger
I just came on to add this suggestion. I have to use the MyFitnessPal app to do these things, and it would be nice not to have to use two separate nutrition-tracking apps. I would also like to be able to copy meals from one day to another (copy, not move).
Laulec108
Recovery Runner
The food logger in Fitbit is becoming MFP replacement for me.  it pretty much has feature parity, EXCEPT for this. Fitbit... Please!
