Android Notifications
Hi, I just got the latest update (Sept 15th) for the android app and it seems like the notifications is now becoming a problem. Let me explain: before I use to receive notification of a call on my charge hr but now after setting it up, a notification always run in he Android drop list. And if I decide to turn it off (which is inconvenient), the fitbit app always reminds me to set it up :s can this be fixed? Tks
Moderator Edit: Added Labels
17 Comments
SunsetRunner
Not applicable
I have the same issue on a Nexus 5, it's extremely annoying.
zesaver
First Steps
The same on my Nexus 4. I like to have call notifications on my Fitbit Charge, but I do not need a permanent reminder that they are turned on. Is it possible to make that line in Android drop list optional? Thanks
MsRicki
Recovery Runner
Since the most recent update, I'm constantly receiving the notification "Notifications are running" and now when my phone rings, although I have the device paired with my phone, I am not receiving my incoming call notification on my device (Charge HR) any longer. Is there a fix for the recent update in the works?
k8marieuk
First Steps
Same problem here, very annoying. I dont need a permanent reminder! Please remove this option or let it be optional.
Status changed to: Reviewed By Moderator
DerrickS
Premium User
Moderator Alum
Moderator Alum
@cmlegend I'd recommend checking out this Community post on how you can turn off notifications in Android App version 2.11. It has a step by step workflow of how you can turn off notifications.
Hope this helps and thanks for posting on the Feature Request Board!
cmlegend
Recovery Runner
That's great for when you don't want to get call notifications... But what about "notifications are running" always showing up in the android notification drop down when it's enabled? I never use to have that when call notifications were enabled in the app...
Barr592e
First Steps
Please remove the permanent notification that says "android notifications are running" from the notification pull down screen.
thebossgod
First Steps
Same issue. When call notifications are enabled, there is a persistant "Fitbit Notifications" notification on my S4. I'd like to be able to keep call notifs enabled, but dismiss the general "Notifcations are running" one.
gekko59
Jogger
Agreed. I nearly uninstalled the app because if I do not enable the notification feature, I get the notification to enable notifications (it dismisses, but returns every so often). If I enable the notification feature, then I have the permanent "Notifications are running" notification.
Do not spuriously and unecessarily clutter the notification bar people!
How I dealt with it: went into settings -> apps and found FitBit. Unchecked the "Notifications" box from there, so now FitBit cannot display any notifications on my phone.
Hopefully FitBit will let me know when they've resolved this irritant and I can re-enable general notifications.
Moderator Edit: Formatting
patbl
First Steps
I am also experiencing the same problem. I don't understand why the developers would think that it is a good idea to put a notification in the drawer that cannot be swiped away?
I like getting notifications on my fitbit but I hate having to put up with clutter on my phone in order to do so. I don't need a continuous reminder of the settings I have selected. I can't imagine what the drawer would look like if every app developer made the same decision.
connolley
First Steps
Ditto. It's annoying.
cmlegend
Recovery Runner
I'm back to a previous version of fitbit... The one where I get call notifications without a constant notification reminder in my drawer.... This sucks!!
zesaver
First Steps
This is an option. Do you have a link for the previous version?
cmlegend
Recovery Runner
The new update has fixed this notification being permanent on your drawers.... It's no more... Thanks fitbit for fixing it
yogeshi
Recovery Runner
When I switch on the Calls & Notification with my Android Phone, even if I am dialing the Phone Number, it Vibrates. I feel it is irritating to get Vibration for Outgoing calls also. Please Correct this Bug Immediately.
Rich_Laue
Community Legend
Go into the Fitbit notification menu and trim off Fitbit notifications.
Status changed to: Released
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi everyone, and thanks for sharing this suggestion. We’re very happy to let you know that this has been released on the Android Fitbit app. You should no longer see the "Notifications are running" message when receiving notifications. You can find more details about how to set up notifications on your Fitbit device here.
@cmlegend, in recognition of your excellent suggestion, each of your votes will now count as 5 votes – you have the power! Thank you for sharing this idea, and thanks to everyone who voted and commented for your enthusiasm which has now materialized for everyone’s benefit. We hope you all enjoy this new addition to the Fitbit product or service!
